Rendered Images
Leapfrog Geo can render high-quality images that you can save on your computer in a format that can be used in presentations and documents. To do this, click on the Render Image button in the toolbar () or click on the Leapfrog Geo menu and select Render Image. Leapfrog Geo renders an image from the current scene window, then displays it in the Render Image window:
The Render Image window showing a rendered scene, with size, aspect, supersampling and overlay controls and a Render button in the toolbar above it
If you are displaying multiple views in the scene, you can select which ones you want to render from the Render View list:
The Render View list open on the Render Image tab, choosing which of the split scene views to render; All (Multi View) is selected and the three panes are shown below
Views that are open in tabs are also listed in the Render View list. However, the All (Multi View) option only renders the split of views displayed in the Scene View tab.
Use the zoom tools to view the rendered image. You can change the image settings by:
  • Selecting a new image size. To constrain the image’s proportions when changing size, tick the Keep aspect box.
  • Changing supersampling options to smooth jagged edges. Select the required option from the list. The highest sampling option (4x4) will take longer to process than the lowest sampling option or turning supersampling off.
  • Viewing the image with or without overlays. See Overlay Settings for more information about further customising the overlays displayed in the scene.
Click the Render button to update the image with the changed settings. Once you are satisfied with the rendered image, click Save. You will be prompted to enter a filename and location.
Background Rendering
You can keep the Render Image tab open while continuing to work in your project, which is useful for rendering a series of images. To work in this way, dock the Render Image tab adjacent to the scene window. When you have set up your scene, right-click on the Render Image tab and choose one of the options:
The right-click menu on the Render Image tab, offering Render and Copy Image and Render and Save Image so rendering runs in the background
The Render and Copy Image option will render a new image from the scene and copy it to the clipboard.
The Render and Save Image option will render a new image and prompt you for a filename and location.
