One Step Correction to Free-air Anomaly
Use the Moving Platform Gravity > One Step Correction to Free-Air Anomaly menu option (AGTOTCOR GX), to calculate the total corrected free-air anomaly in one step.
One Step Correction to Free-Air Anomaly dialog options
Latitude channel
The latitude channel name. The default name is "Latitude".
Script Parameter AGTOTCOR.LAT
Longitude channel
The Longitude channel name. The default name is "Longitude".
Script Parameter AGTOTCOR.LONG
Height channel
The elevation of the observation platform. For airborne surveys, this is the height above the sea level. The default will be set to "Height", if a channel by this name exists in the current database.
Script Parameter AGTOTCOR.HEIGHT
Hours to GMT (+ in West)
(optional)
This is the time difference between the time recorded in the survey database and GMT. This is a positive number in the Western hemisphere.
If this field is left blank, no tide correction is applied.
Script Parameter AGTOTCOR.GMT
Input absolute gravity channel
The absolute gravity channel name. The default name is "AbsGravity".
Script Parameter AGTOTCOR.INCH
Output Free-air anomaly channel
The total corrected free-air anomaly channel name. The default name is "Free-air".
Script Parameter AGTOTCOR.OUTCH
The Total Correction includes the Vertical Acceleration, Eötvös, Tide (optional), Latitude, and Free-air corrections:
Total Correction = Vertical Acceleration Correction - Free Air Correction - Eötvös Correction + Latitude Correction - Tide Correction (optional)
To obtain the Free-air anomaly, the Total Correction is subtracted from measured values of absolute Gravity from the L+R meter in mGal (Gabs).
