Coordinate System - Custom Datum
Use the Custom Datum dialog to define a new custom datum for the selected projection. This is useful when your custom projection may use a custom major axis and flattening.
Custom Datum dialog options
After the dialog is closed, you will be prompted to create a local datum transform for the new datum:
- Selecting "Yes" in the dialog will open the Custom Local Datum Transform dialog to define the new local datum transform (LDT).
- Selecting "No" will take you back to the Modify Coordinate System dialog and set the description for the LTD to "None applied". You can later simply delete the custom datum entry and create a new one if you want to define a new local datum transform for your custom datum.
Once the parameters are defined, the custom datum will be added to the file datum.csv and to any other files that need to be aware of it (i.e., ldatum.csv, datumtrf.csv, ellipsoid.csv, ipj_pcs.csv). The files are saved in the user folder %USERPROFILE%\Documents\Geosoft\Desktop Applications\csv.
See the Datum Definition Table for a complete list of CSV files containing projection information.
