Voxel to UBC
Use the Voxel > Conversions > Voxel to UBC menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ExportVoxToUBC;Run)*) to export a Geosoft Voxel to a UBC MSH/MOD file.
Voxel to UBC MSH/MOD dialog options
Voxel file |
Select the Geosoft Voxel file to export. Script Parameter: EXPORTVOXTOUBC.INPUT_VOXEL |
UBC MSH file |
Specify the name of the UBC Mesh file to create. A model file, using the same file name, but with the extension "MOD" is created at the same time. Script Parameter: EXPORTVOXTOUBC.UBC_MSH_FILE |
Output dummy value |
Specify the value to output for dummies. Default is -1 for this format. Script Parameter: EXPORTVOXTOUBC.DUMMY_VALUE |
