UBC to Voxel
Use the Voxel > Conversions > UBC to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportUBCToVox;Run)*), to import UBC 3D Model & Mesh files to a Geosoft Voxel.
UBC Mesh Tools 3D Model to Voxel dialog options
Output voxel |
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel). Script Parameter: IMPORTUBCTOVOX.OUTPUT_FILE |
Model file |
Browse to select the UBC Model file to import. Script Parameter: IMPORTUBCTOVOX.MODEL_FILE |
MSH Header file |
Specify the Mesh file (*.msh) containing a description of the 3D mesh. See below for the format. Script Parameter: IMPORTUBCTOVOX.MSH_HEADER_FILE |
Dummy value |
Specify a value to be interpreted as dummy in the import. Script Parameter: IMPORTUBCTOVOX.DUMMY_VALUE (default -9.0) |
Coordinate System
Coordinate System |
The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the incoming UBC 3D Model/MSH file. Script Parameters:
If a 3D Viewer is open during the import, then the output voxel will be displayed in that 3D view. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
MSH Header File Format
This file contains the 3D mesh which defines the model region.
The mesh has the following structure:
E0 N0 V0
?E1 ? E2 ... ? ENE
? N1 ? N2 ... ? NNN
?V1 ? V2 ... ? VNV
NE Number of cells in the East direction.
NN Number of cells in the North direction.
NV Number of cells in the vertical direction.
E0, N0, V0 Coordinates, in meters, of the southwest top corner, specified in (Easting, Northing, Elevation).
Model File Format
Model files consist of a total of NE*NN*NV values - one per line.
Example:
-9.0000000e+000
1.0607292e+001
1.0642567e+001
1.0762947e+001
1.0782325e+001
1.0803412e+001
1.0837755e+001
etc...
File structure of model .sus:
sus1,1,1
sus1,1,2
sus1,1,NV
sus1,2,1
susi,j,k
susNN,NE,NV
susi,j,k susceptibility at location [i j k].
[i j k]=[1 1 1] is defined as the cell at the top-south-west corner of total number of lines in this file should equal NN NE NV, where NN is the in the North direction, NE is the number of cells in the East direction, and NV cells in the vertical direction. The lines must be ordered so that k changes the 1 to NV), followed by j (from 1 to NE), then followed by i (from 1 to NN).
The dummy value is -9.0, and is automatically converted to a Geosoft dummy on import.
The above descriptions are derived from the following document: MAG3D
A Program Library for Forward Modelling and
Inversion of Magnetic Data over 3D Structures
VERSION 3.0
Developed under the consortium research project
JOINT/COOPERATIVE INVERSION OF
GEOPHYSICAL AND GEOLOGICAL DATA
UBC–Geophysical Inversion Facility
Department of Geophysics and Astronomy
University of British Columbia
Vancouver, British Columbia
