Export Map to BMP or PLT
The EXPMAP GX exports a map to a bitmap or external plot file.
Script Parameters
View Mode Script Parameters
View |
Name of the View to export coordinates in. Script Parameter: EXPMAP.VIEW |
Resolution |
Resolution of a pixel in view units. This parameter is used to size any raster images exported. Script Parameter: EXPMAP.RES |
Export Format |
Type of output file to create:
Script Parameter: EXPMAP.FORMAT |
Raster Mode Script Parameters
SizeX |
Number of pixels in the X direction to export. This and the SiseY parameter together define the output size. However, the user should only specify one of these options and place 0 for the unspecified one. The software will automatically compute the unspecified parameter to keep the aspect ratio of the exported map. Script Parameter: EXPMAP.SIZEX |
SizeY |
Number of pixels in the Y direction. See SizeX for comments. Script Parameter: EXPMAP.SIZEX |
Export Format |
The following output formats are supported in Raster mode:
