Grid Profile
Use the Grid and Image > Utilities > Grid Profile menu option (GRIDPROF GX) to extract a data profile from up to five grids and place them in a new line of the current database. If a database is not open, you will be prompted to either create one or select an existing one. This capability can be useful for a variety of applications including modeling and removing local trends during gridding.
Grid Profile dialog options
Projections
Care must be taken when choosing between the digitizing methods. Both the "digitise from map" and "manual input – map coordinates" methods assume that the entered locations are given in map coordinates. Because the database X and Y channels may have a different projection than the current map data view, the X and Y locations written to the database may be different from those digitised or entered manually. However, the shadow cursor should map between the two faithfully, and a line path drawn on the map from the database profile should match the locations entered from the map. The "manual input" method assumes that the coordinates are given in terms of locations in the current X and Y channels. If the X and Y channels do not have a projection defined, then the X, Y channel projection is set to be that of the first grid. In either case, the values displayed are the same as those expected from the entered values.
Implement Local Trended Gridding
The bi-directional gridding algorithm (BIGRID) enables you to grid using local trend lines and removes local effects that can degrade the quality of final maps. The basic procedure is to extract a profile from the grid you are working with, convert it to a trend line, and then run the Bi-directional gridding option.
Once the profile has been extracted (GRIDPROF GX) and the line created in the database, scroll to the new line and select the ID Cell for the line: right click and select Edit from the popup menu.
In the Edit Line dialog, change the line type to "TREND" and click OK.
Now run the Bi-directional gridding option. The system will include the local trend line in the gridding process.
Running GRIDPROF as a Script
This GX may now be run as a script; however, the profile positions must be entered using the "manual" option. Points entered using the "digitizing" option are not stored as script parameters. Up to five locations may be entered.
GRIDPROF1.1Y
GRIDPROF1.2X
GRIDPROF1.5X
GRIDPROF1.5Y
Existing lines in the database will be overwritten. (There is a warning prompt in interactive mode).
