Import ASEG-GDF
Use the Database > Import > ASEG-GDF > Import GDF (IMPASEG GX) to import ASEG-GDF data.
Import GDF dialog options
Data may now be imported directly into a database using the IMPASEG GX, without using a pre-existing template. It is necessary, however, to specify at least one of the Data (.dat) or DEFN (.dfn) file names. If only one of the data or DEFN files is specified, the other is assumed to have the same name with the appropriate extension, either .dfn or .dat.
Import Templates
The import ASEG-GDF data may be customized by creating an import template file (with default extension .I4). This is an ASCII file that specifies the channels of data that you would like to import and the database channel in which you would like to place the data. The SCANASEG GX can be used to scan a given ASEG-GDF DEFN file and create a default import template that will import all data contained in the data file. Alternatively, if no template is specified when using the IMPASEG GX, a template is automatically created during import with the same name as the data file and with the .i4 extension. This may be edited and used to import a subset of channels, or rename channels on import.
Following is an example of a ASEG-GDF import template:
DEFN BOOTHILL.dfn
DATA BOOTHILL.dat
FLC FLTLINE
IMPORT FLIGHT,FLIGHT,SHORT
IMPORT DATE,DATE,LONG
IMPORT TIME,TIME,FLOAT
IMPORT FIDUCIAL,FIDUCIAL,FLOAT
IMPORT ALTITUDE,ALTITUDE,FLOAT
IMPORT TMAGRAW,TMAGRAW,FLOAT
ALIAS L20440,L20440
ALIAS L20450,L20450
The template file is searched for the line [IMPORT ASEG-GDF], and the IMPORT and ALIAS lines that follow are read to determine what data to import and the channels in which to place the data. You may add any comment line you wish before the [IMPORT ASEG-GDF] line.
DEFN syntax:
where file_name is the name of the ASEG-GDF DEFN file to import.
FLC syntax:
where flight_line_channel is the name of the ASEG-GDF channel containing the flight line information.
IMPORT syntax:
The name is the name used in the ASEG-GDF DEFN file to indicate the data name. The channel is a mapping to the channel that will be created in the database. And the data type (one of BYTE, UBYTE, SHORT, LONG, FLOAT or DOUBLE) which should correspond to the type in the DEFN file.
ALIAS syntax:
As the ASEG-GDF lines are imported, if a line-channel already exists in the database, it will be replaced. The ALIAS statement in the import template can be used to re-name lines of the ASEG-GDF data file during import. If the new_line_name is blank, the line will not be imported.
If ALIAS is used, ALL lines contained in the ASEG-GDF file must be defined by an ALIAS line in the same order that the lines appear in the file. The SCANASEG GX can be used to construct a default template that includes ALIAS lines for all lines of a file. This file can be edited as required by the system.
For example, if a file contains line L90, two sections of line L100 and a tie line L30, the following ALIAS lines can be used to import the data into properly named lines:
ALIAS L100,L100.0
ALIAS L100,L100.1
ALIAS L30,T30
Setting Coordinate Systems
If the "Specify coordinate system on import" setting is set to "Yes" in the General Settings, and if no coordinate system is defined in the current X and Y channels, the "Georeference Database Channels" dialog is called so that the projection can be set on the X and Y.
