Scan ASEG-GDF
Use the Database > Import > ASEG-GDF > Scan GDF (SCANASEG GX) dialog to scan a given ASEG-GDF file and create a default import template. The template can be edited and modified to remove unwanted channels and to re-name lines as required using the ALIAS keyword.
Scan GDF dialog options
ASEG-GDF DEFN file to scan |
ASEG-GDF DEFN file name. By default, the browse window shows file with the ".dfn" extension. Script Parameter: SCANASEG.DEFN |
ASEG-GDF Data file to scan |
ASEG-GDF data file name. By default, the browse window shows file with the ".dat" extension. Script Parameter: SCANASEG.DATA |
Flight Line channel name |
Flight Line Channel name. By default the "Line" channel is used. Script Parameter: SCANASEG.FLC |
Create ASEG-GDF template file |
Template file name (.I4 assumed). Script Parameter: SCANASEG.TEMPLATE |
