Multiple Profile Plot - Line Styles Options
Use the Line Styles tab to change the profile line style for the selected channel.
Channel Options: Line Styles Tab
Select a style
Select a line style for the current profile. The style selected (Standard, Medium, Heavy, Long Dash, Short Dash, None) is illustrated in the Example window on the bottom right of the dialog.
Options
Break on dummy values
Check this option to display the profile line with breaks where no data (dummy values) are found. The changes are reflected in the Example window.
Wrapping
Check this box to wrap the profile data . Wrapping enables the section of a profile, which may go beyond the profile window, to be displayed at the bottom of the profile. The applied wrapping is shown in the Example window.
