AGGR (place an aggregate image on the map)
This command, which is part of the MAPPLOT GX, can be used to construct an aggregate and place it on the map. An aggregate is an image on the map that is made up of one or more image components.
Command Syntax
agg_name
image,zone,method,contour
(*repeated any number of times)
Only first-level commands can begin in the first column; all arguments/sub-command parameters need to be indented with spaces. See the Example section below.
Command Parameters:
refp |
Place the aggregate relative to this reference point. This will normally be reference point 0 for data images, or one of the map reference points for logos and bitmaps. |
x1,y1,x2,y2 |
Optional rectangular area within which to place the aggregate. If not specified, the aggregate location will be placed based on location defined in the image headers. |
aspect |
If a placement area is defined, this parameter controls the X and Y scaling relative to the defined area: |
0 |
Fit the aggregate to fit the area exactly. |
1 |
Preserve the aspect ratio of the aggregate. |
Sub-Command Parameters Line 1:
agg_name |
The aggregate name in the map. By convention, Geosoft normally used the prefix "AGG_" on aggregate names. |
Sub-Command Parameters Line 2:
Example
MGRP Mag,0,1 |
MGRP Logo,0,0 |
MGRP IndexMap,0,0 |
