ALAT (annotate latitudes)
This command will annotate latitudes along the East and West edges of the currently defined data window. A map projection must be defined to use this command. Map projections can be defined using the PROJ command or may be defined in the MDF file read in by an MDFF command.
Command Syntax
att,height,width,space,slant,font
Command Parameters:
lsep |
Separation in deg.mmss (decimal degrees) between annotations. If not specified, the dy separation defined by a previous GRID command will be used. |
tick |
The size of map edge ticks in map units. The default is 0.5cm. A negative tick size will cause ticks to be outside of the map. Ticks will be drawn in the currently defined attribute, and in the direction of latitude. |
postoff |
Offset of the annotation posting from the map edge. The default is 0.15 cm. |
side |
Side of the map to annotate |
-1 Annotate the left edge only. |
0 Annotate both the left and right edges. |
1 Annotate the right edge only. |
edge |
Controls justification of annotations near the top and bottom edges of the data window. This only matters if orient is not 0. |
0 Center all annotations. |
1 Left and right justify annotations near the map edges and center all other annotations. |
orient |
Controls the orientation of latitude annotations. |
-1 Annotated vertically, tops of annotations point out from the data. |
0 Annotate horizontally, annotations left or right justified on edge. |
1 Annotate vertically, tops of numbers point into the data. |
Sub-Command Parameters:
att |
Attribute to use for annotations. Note that ticks will use the attribute defined before the ALAT command. |
height |
Character height in map units. (default 0.25cm) |
width |
Character width in map units. (default same as height) |
space |
Character spacing in map units. (default same as height) |
slant |
Character slant in degrees from vertical. |
font |
Text font name. |
Example
PROJ UTM17
RECT 12
DATT ann=kt100
ALAT 2.3,0,,1,-1
ALON 2.3,0,,1
GRID -2
This will annotate longitude and altitude at the edges of the data window. The GRID command will cause a grid to be drawn, which makes edge ticks redundant, so the tick size has been set to 0.
