BARV (draw an annotated vertical scale bar)
This command draws a ticked and annotated vertical scale bar at the edges of the currently defined data window.
Command Syntax:
label,dec,offs,just,angle,att,ht wd,sp,slant,font
title,tref,dx,dy,just,angle,att,ht,wd,sp,slant,font
Command Parameters:
side |
Side of window to draw vertical scale bar |
offs |
Offset from window edge in map units. The default is no offset |
asep |
Separation between tick marks in world coordinates. The default is chosen based on window dimensions. |
tick |
Size of major tick marks in map units. The default is 0.15 cm. |
sub_tick |
Sub-ticks are placed at sub_tick divisions between major ticks. If sub-tick is 1 (the default), no sub-ticks are added. A sub_tick value of 2 adds a single sub_tick half-way between each asep major tick. |
att |
Attribute used to draw the scale bar. |
Sub-Command Parameters Line 1:
This line controls the annotation of the scale bar. If the bar is annotated, only the major ticks are labelled.
label |
Label annotation of scale bar |
0 Do not annotate the bar. |
1 Annotate the bar (default) |
dec |
Decimal places |
-3, -4, etc. Exponential with (0, 1, etc.) decimal places (values equal to or less than –3) |
-2 Full precision (Default). |
-1 Integer. |
0, 1 etc. Number of decimal places (values equal to or greater than zero) |
offs |
Annotation offset from the bar. Default: 1.5 times the tick size. |
just |
Text alignment |
-1 left justified (Default for side = 1) |
0 Centered |
1 right justified (default for side = -1) |
angle |
The angle in degrees counter-clockwise from the X-axis at which to annotate the axis |
att |
Annotation attribute. |
height |
Annotation height. |
width |
Annotation width. |
space |
Annotation spacing. |
slant |
Character slant (Default 0) |
font |
Text font. |
Sub-Command Parameters Line 2: (this line can be repeated)
This line controls the title of the scale bar.
title |
Scale bar title enclosed in double quotes (" "). |
treff |
Title location |
1 title plotted under the bar |
2 title plotted centered on left or right edge of the bar, depending on side. (Default) |
3 title plotted above the bar |
dx |
X location relative to the bar at which to plot the title next. The default X location is based on the treff option. |
dy |
Y location relative to the bottom of the bar at which to next plot the title. The default Y location is based on the treff option. |
just |
Title alignment |
-1 left justified (default for side = 1) |
0 centered |
att |
height |
Title height. |
width |
Title width. |
space |
Title spacing. |
slant |
Title slant (Default 0) |
font |
Text font. |
Example
WIND 1,5,15,35,23 /DEFINE A DATA WINDOW
WDEF 0,50000,1000,55000 /MAP WINDOW TO X,Y BUFFERS
RECT 12 /DRAW A BOX AROUND WINDOW
BARV –1 /DRAW A BAR ON THE LEFT EDGE
BARV 1 /DRAW A BAR ON THE RIGHT EDGE
1 /DEFAULT ANNOTATE BAR
"MAG" /ADD TITLE TO RIGHT BAR
This control file will define a page with a 30 x 8 cm window. World coordinates are mapped to the window and these coordinates are annotated on the left and right edges of the window.
