BUFF (Set the length of the XYZ buffers)
This command can be used to re-set the length of the buffers as desired. The XYZ buffer size will use 60% of available memory by default.
Command Syntax:
BUFF length
Command Parameters:
length |
The maximum number of points for the XYZ buffers. If you attempt to set the buffer size larger than the available memory, the length will be reduced to fit. |
