DWND (Window data in the XYZ buffers)
The DWND command removes data from the X, Y or Z data buffers that are outside of a specified range.
Command Syntax:
Command Parameters:
xyz |
Specify either the 'X', 'Y', or 'Z' buffer on which to apply windowing |
min |
The minimum value below which data is removed. The default is the minimum of the data. |
max |
The maximum value above which data is removed. The default is the maximum value in the buffer. |
Example
DOPN mag,2 /open MAG.XYZ to read second Z
DXYZ L100 /read Line 100 into buffers
DWND Z,10,100 /window Z values from 10 to 100
DMOV Z,Y /move Z into Y buffer
WIND 1,4,10,20,23 /define a data window on page
WDEF ,,,,,,1 /scale window to plot buffer
LINA 0 /plot buffer as world coord.
