FONT (Select a font)
The FONT command sets a new font to be used for subsequent text and numbers.
Command Syntax:
Command Parameters:
name |
The name of the font. The font may either be any True Type font installed on the computer, or may be selected from the available Geosoft stroke fonts. To select a True Type font, add "(TT)" to the font name. For example: FONT "Time New Roman(TT)". By default, the font type is assumed to be a Geosoft stroke font. Stroke font sets are defined in GFN files, which are located in the GEOSOFT directory and have extension GFN. The following stroke fonts are available: |
Sr |
simplex roman |
Ss |
simplex script |
Cr |
complex roman |
Ci |
complex italic |
Tr |
triplex roman |
Ti |
triplex italic |
Dr |
duplex roman |
Cs |
complex script |
Sg |
simplex Greek |
Cg |
complex Greek |
Es |
equal-spaced simplex roman |
Fast |
fast but ugly |
Russian |
a simple Cyrillic font |
If a Geosoft font name conflicts with a True Type font name, the Geosoft font can be specified explicitly by adding "(GFN)" to the font name. For example:
Example:
The FONT command causes an attribute override to be used whenever text is placed in the plot file.
FONT cr
TEXT 1,5,1,0,"Centered Title"
FONT "Arial(TT)"
TEXT 1,3,1,0,"True Type Sub-Title"
This loads font file CR.GFN (Complex Roman) and then plots subsequent text using this font.
