RECT (Draw a rectangle)
The RECT command draws a rectangle on the map. The rectangle will be colour filled if a fill colour is defined in the attribute used.
Command Syntax:
RECT refp,x1,y1,x2,y2,att,style,pitch
                                                    Command Parameters:
Example
MDFF M1
                                                    RECT -1 \ draws a line around the map edges
RECT -2 \ draws a rectangle around the data area
RECT 1,10,10,50,40,rect:k0R,4
This draws three rectangles: one around the map, one around the valid data area as defined in M1.MDF, and a 40 x 30 cm and a red rectangle 10 cm above and right of the map origin.
