SURR (Draw a map surround)
The SURR command draws a single or double line surround through the map reference points.
Command Syntax:
SURR p1,dx,p2
Command Parameters:
p1 |
att to use for outer surround line. The outer surround passes through the map reference points. The default is :t450 |
dx,p2 |
Offset (in map units) and attribute for inner surround line. The default is not to plot inner line. If plotted, the default attribute is :t300. |
Note: If an inner surround line is drawn, then map reference points 1 through 9 are shifted to lie on the inner surround line.
Example
MDFF m1
SURR 3,.2,1
This draws a double surround.
