TITL (Draw a title block)
The TITL command plots a title block. The title block is a rectangular block that is divided horizontally into 4 optional areas in which text can be written. The text areas are referred to as, from top to bottom, A,B,C,and D.
Each line of text is defined in a separate sub-command line. The width of the block can be specified by the user and the height is dependent upon the text heights and number of text lines that are included.
Command Syntax:
just,att,height,width,space,slant,font
Command Parameters:
Sub-Command Lines:
Text lines must be entered consecutively from top to bottom. White space can be controlled by entering blank lines of appropriate text height.
area |
Text area (A,B,C or D) in which to place text. (No Default) |
"text" |
Text to plot surrounded by quotes. |
just |
specifies text position in text window: |
-1 |
left justified |
0 |
centered (Default) |
1 |
right justified |
Base line justification is not supported in the title block. |
att |
Attribute to use for text. The defaults are smlatt for areas A,C and D, and bigatt for area B. |
height |
Text height. Space actually occupied by text is 1.1 times as large as height. (Default heights are 0.6 cm. for areas A,B and D, and 0.4 cm. for area C.) |
width |
Text character width. The character width will be reduced if the text string is too long to fit. The default is the character height. |
space |
Spacing of characters in cm. (Default is the character width.) |
slant |
Slant of the characters in degrees from vertical. The default is the last slant specified. |
font |
Text font (default is current font). Refer to the FONT command for descriptions of the available fonts. |
Example
SURR
TITL 3,0,0
a,"Client Name"
b,"Map Title"
b,"Sub-Title"
c,"descriptive text"
c,"more descriptive text"
d,"Company Name"
Draws a title block in the bottom right corner of the map.
