Apply Custom Contours
Use the Map Tools > Contour > Contour menu option (SCONT32 GX) to contour a grid and provide access to contour parameters.
The method lets you interactively set up a contouring scheme comprising:
- Custom contouring options
- Up to eight line styles
- Corresponding line labels
To apply custom contouring:
Open the map to which you want to add contours.
On the Map Tools menu, select Contour > Contour: the Contour dialog is displayed.
Select the grid to be contoured, the basic contouring option and the contour levels.
Click the Options button. The system displays the Contour Options dialog.
Set any parameters as required and click OK.
The Contour dialog is again displayed. Click the Line Styles button. The system displays the Line Colour and Weight dialog.
Select the weight and colour you want to use for each contour level.
Click the Next> button to display the Line Styles dialog.
From the drop-down lists, select the line styles for the contours.
Click the Next> button to display the Label Lines dialog.
From the drop-down list, specify which contour levels you want to label on your map.
Click Finish to return to the main dialog. Click OK to display the contours on your map.
Contour dialog options
The name of the grid to contour. Script Parameter: CONTOUR.GRID |
Contouring option |
Select "multiples of levels" (0) to plot the levels and their multiples or "exact levels" (1) to plot only the exact stated contours Script Parameter: CONTOUR.TYPE |
(smallest) Interval level 1 |
The first level, which must be the smallest Script Parameter: CONTOUR.LEV1 |
Interval level 2 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV2 |
Interval level 3 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV3 |
Interval level 4 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV4 |
Interval level 5 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV5 |
Interval level 6 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV6 |
Interval level 7 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV7 |
Interval level 8 |
The next level, larger than the previous. Script Parameter: CONTOUR.LEV8 |
[OK] |
This button starts contouring. |
[Options] |
This button displays the Contour Options dialog box. |
[Line Styles] |
This button displays the first of three line-style dialog boxes. |
Contour Options dialog options
Line Colour and Weight dialog options
Line weight – colour level 1 |
Allows you to select the line weight and colour for each of the eight basic contour levels. Script Parameter: CONTOUR.COL1…COL8 |
Line Styles dialog options
Line styles level 1 |
Allows you to select the line style for each of the eight basic contour levels. Script Parameter: CONTOUR.STY1...STY8 |
Label Lines dialog options
Label level 1 |
Allows you to turn on and off contour labeling for each of the 8 basic contour levels. Script Parameter: CONTOUR.LAB1...LAB8 |
More complete control of contouring options is available through the contour control file, which is documented under Contour with a Control File.
