Sort All by 2 Channels
Use the Database Tools > Channel Tools > Sort All by 2 Channels menu option (SORTALL2 GX) to sort all channels based on two reference channels. The data is first sorted by a primary reference channel, then for data with the same value in the primary reference channel, the data is sorted by the secondary channel.
Sort All by 2 Channels dialog options
Primary channel: |
Primary channel on which to base the sort. The data will first be sorted by this channel, then by the secondary channel. Script Parameter: SORTALL2.CHANNEL1 |
Primary sort: |
Ascending or Descending. Script Parameter: SORTALL2.ORDER1 |
Secondary channel |
Secondary channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel. Script Parameter: SORTALL2.CHANNEL2 |
Secondary sort |
Ascending or Descending. Script Parameter: SORTALL2.ORDER2 |
Sort read-only channels? |
Yes to sort read-only channels, No to not sort read-only channels. Script Parameter: SORTALL2.READONLY |
If a channel is not sampled at the same rate as the reference channels, the reference channels are re-sampled to match the channel being sorted.
Note that .
If protected channels are not sorted, the fiducial relationships will be lost, and data integrity may be lost.
