Lithology to Numeric Voxel
Use the Voxel > Conversions > Lithology to Numeric Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ConvertThematicVoxelToNumericVoxel;Run)*), to convert an existing Lithology Voxel to a new numeric Voxel.
Lithology to Numeric Voxel dialog options
Input lithology voxel |
Select the voxel file to be converted. Script Parameter: TRANSLATE_THEMATIC.INPUT_VOXEL |
Output numeric voxel |
Specify the name of the numeric voxel file to generate. Script Parameter: TRANSLATE_THEMATIC.OUTPUT_VOXEL |
Lithology table |
Browse to select the lithology file (*.csv). Script Parameter: TRANSLATE_THEMATIC.THEME_FILE |
Output property |
Specify the property to use in the conversion. Script Parameter: TRANSLATE_THEMATIC.OUTPUT_PROPERTY |
Input Voxel
The input voxel must be a lithology (thematic) voxel.
Output Voxel
The resultant voxel has a data type of FLOAT.
Lithology Table
The lithology table must be a valid comma separated values (CSV) file and must have a lithology classification field named "Code", as well as a field containing the numerical values to assign to each code.
Output Property
The output property must be a numeric field in the lithology table.
If a 3D Viewer is open when running the conversion, the output numeric voxel will be displayed in the 3D Viewer window.
Otherwise, the output voxel will be displayed into a new Voxel Viewer window.
