Numeric to Lithology Voxel
Use the Voxel > Conversions > Numeric To Lithology Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ConvertNumericVoxelToThematicVoxel;Run)*), to convert an existing numeric Voxel to a new Lithology Voxel.
Numeric to Lithology Voxel dialog options
Input numeric voxel |
Select the voxel file to be converted. Script Parameter: TRANSLATE_NUMERIC.INPUT_VOXEL |
Output lithology voxel |
Specify the name of the lithology voxel file to generate. (.geosoft_voxel). Script Parameter: TRANSLATE_NUMERIC.OUTPUT_VOXEL |
Lithology table |
Browse to select the lithology file (*.csv). Script Parameter: TRANSLATE_NUMERIC.THEME_FILE |
Input property |
Specify a property to use in the conversion. Script Parameter: TRANSLATE_NUMERIC.INPUT_PROPERTY |
Input Voxel
The input voxel must be a numeric voxel.
Output Voxel
The resultant voxel will have a 32 bit integer format. Should the input voxel have data ranges outside the data range that is specified in the lithology table, those values will be converted to dummy values.
Lithology Table
The lithology table must be a valid comma separated values (CSV) file and must have a lithology classification field named "Code", as well as a column of associated values used to convert to the associated codes.
Input Property
The input property must be a numeric field in the lithology table.
Conversion Algorithm
Numerical values in the input voxel are assigned codes based on the following method:
- Values in the selected numeric field in the lithology table are sorted in ascending order, along with the codes.
- The range of values for each code extends half-way to the values for its adjacent codes.
- The "outside" ranges for the minimum and maximum values are calculated using the "inside" range to the nearest values.
- Any values falling outside the minimum or maximum range values are not assigned a lithology code, and so that cell will not appear in the output voxel.
For instance, if "Red", "Green" and "Blue" have values 0, 2 and 5, then the following ranges are calculated: Red (-1 to 1), Green (1 to 3.5) and Blue (3.5 to 6.5).
If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxelsoption is set to "True".
