Linear Transform
This dialog opens when you click the Use a linear distribution button from the Create Multiple Isosurfaces from Voxel dialog box. The minimum and maximum values defined in the Linear Transform dialog are used to define a linearly-spaced set of isosurface values.
Linear Transform dialog options
Minimum |
The Minimum value is initially set to the minimum voxel data value. It can be adjusted to any value in the voxel’s data range, and must be less than the value entered for Maximum. Script Parameter: SURFACEBROWSE.MIN |
Maximum |
The Maximum value is initially set to the maximum voxel data value. It can be adjusted to any value in the voxel’s data range, and must be greater than the value entered for Minimum. Script Parameter: SURFACEBROWSE.MAX |
