Array Profile Plotting
In the database window, use the right-click menu option Array Profile Plotting (VAPLOT GX) to plot an individual array profile from an array channel in the current database. This GX must be run interactively.
Plot Individual Array Profile dialog options
Title |
Enter a title to be placed at the top of the figure. |
X Axis Annotation |
X-axis annotation to be placed at the bottom of the figure. |
Y Axis Annotation |
Y-axis annotation to be placed at the right of the figure. |
Width |
Figure width. |
Height |
Figure height. |
Colour |
Figure colour. |
The plot Y-axis will be labelled to decimal number as displayed in the data channel. You can control the number of decimals displayed by changing the decimals in the channel definition.
A new map will be created to hold the figure. The map name will be "database_line_fidnum.map".
If the map exists, you will be prompted to confirm that you want to overwrite the map. If you do not want to overwrite a map, you must enter a different map name or rename the existing map which can be done by opening the map and using Map/Save as….
