Full Level
Use the Full Level menu option (FULLEV GX) to adjust the values of an input channel by adding a correction defined in a error channel. The correction is linearly interpolated between defined values.
Level to Cross Lines dialog options
The cross-line level error corrections can be extracted from an intersection table using the Load Corrections menu option. You can access this dialog by selecting the Load Corrections on the LevTieLine menu.
The ends of lines that extend beyond the last crossing line will be adjusted using the error at the last crossing. All other parts of the line are adjusted by assuming a linear error between crossing points.
