Tilt Correction
Use the Tilt Correction menu option (LVTILT GX) to create a tilt level correction channel from an error difference channel. The correction is calculated as the first order trend through the level errors (differences) at each crossing.
Create a Tilt Level Correction Channel dialog options
Use the GX to calculate a trend (tilt) that can be removed from lines minimise levelling errors. The resulting correction channel can be subtracted from the unlevelled data using the LVCORR GX.
