Shift Correction
Use the Shift Correction menu option (LVSHIFT GX) to create a level shift correction channel from an error difference channel. The correction is calculated as the average of the level errors (differences) at each crossing.
Create a Level Shift Correction Channel dialog options
Use this GX to calculate average shifts that can be applied to lines minimize leveling errors. The resulting correction channel can be subtracted from the unleveled data using the LVCORR GX.
