Voxel
Voxel is just another word for a three-dimensional grid. The Voxel menu includes options for creating, displaying, processing and converting 3D grids:
You can create a voxel using the voxel gridding options on the Voxel > New menu:
The 3D Kriging option uses a basic statistical kriging algorithm to create a 3D voxel grid from 3D data contained in a Geosoft Database (GDB file). To create a voxel grid, you will need to have a data set that contains X, Y, and Z fields that locate the data within a coordinate system in which Z coordinates are interpreted as positive up.
In addition, you can also perform 3D Direct Gridding and 3D Inverse Distance Weighted Gridding.
These voxel grids can be displayed and manipulated in three dimensions using the Voxel > Open option.
You can view voxel statistics using the Voxel > Properties option.
You can produce a new voxel from a math expression, which works on a point-by-point basis, using the Voxel > Voxel Math option.
You can also convert to or from other 3-dimensional grid formats, such as the UBC Meshtools format and the GoCAD voxel format, using one of the Voxel > Conversions menu options.
