Manage 3D Snapshots
You can use the Manage Snapshots dialog to view, rename, delete or re-order the appearance of your 3D snapshots. The Manage Snapshots option can be found on the Tools & Settings menu of the 3D Viewer and on the 3D View pop-up menu.
In the Manage Snapshots dialog, you can do the following:
Select a snapshot from the list to display it in the Preview window.
Click the View in 3D button (
) to display the selected snapshot in the open 3D view behind the dialog.
Use the Arrow buttons (
) to change the sequence of your snapshots in the list.
Rename a snapshot in the Snapshots list by clicking twice on the name.
Add additional context to a snapshot in the Description field.
Use the Delete button (
) to permanently remove a snapshot from the list.
3D View snapshots are “bookmarks” of individual states of your current 3D View; they enable you to capture and return to a favourite location and state of a view quickly and easily. For example, if you are working on a complex 3D model and would like to share a number of different views with your colleagues, you can create a number of snapshots that will save individual states of the view based on the viewing angle & location, the 3D View extents and display settings, as well as groups visibility, transparency and clipping.
