The 3D Viewer
When you choose to open or create a new 3D View, the window in which the 3D View will be displayed is called a 3D Viewer. This topic briefly describes each of the components of the 3D Viewer and provides links to more information for each one.
Parts of the 3D Viewer
The 3D Viewer consists of the following:
3D Viewer window
3D Viewer Menus
There are six menus found across the top of the 3D Viewer. These are:
Help (opens this topic)
3D Manager
The 3D Manager shows you a list of all the datasets in the 3D View and their current visibility status (on/off).
You can control the visibility of multiple datasets by organizing them into folders and sub-folders.
Clicking on any object in the list allows you to see more detailed information about that object in the Attributes pane, and to modify certain features of the objects. You are able to modify various visual display attributes, such as transparency and colour settings for each object; you can add or delete planes, surfaces and other 3D objects. The 3D Manager also includes tools for modifying and controlling visual clipping of the 3D View.
Learn more about the 3D Manager.
3D Viewer Navigation Toolbar
The following viewing and navigational tools are provided on the toolbar directly above the 3D Viewer window.
Click on the image below for instructions on how to use these navigation and viewing tools:
Most of the navigation tools are also available by right-clicking anywhere in the view.
3D Viewer Status Bar
The status bar across the bottom of a Viewer captures useful information and displays helpful navigation hints under the following sections:
- Coordinate System: the current coordinate system of the 3D document.
- Location under the mouse cursor: the name of the object beneath the cursor and the (X,Y,Z) location of the cursor as you move it on the selected object.
If the view is in motion (e.g., spinning, rotating, panning, zooming), the object identification and reporting of cursor coordinates are paused, and the status bar section will simply display "None". The information is reported back once the view is no longer in motion and you move the mouse over the visible object.
- Location of the shadow cursor: the shadow cursor location when the Shadow Cursor mode is enabled on the 3D Viewer Toolbar.
When the Shadow Cursor mode is enabled, clicking anywhere on the view sets the cursor position and sends it to any other open documents (e.g., maps, databases, 3D views).
- Information about orientation and look-at point of the view: the inclination, azimuth and look-at point (centre of rotation) for the current view location.
