Convert Elevation Grid to Surface
Use the Convert Elevation Grid to Surface option (geogxnet.dll(Geosoft.GX.Surface.ImportGridToSurface;Run)*), to convert the X,Y,Z points in an elevation grid to vertices of an equivalent relief surface. The resulting surface may be saved to either a new or an existing geosurface file. If a 3D View is open in your workspace, the target geosurface file will be displayed.
You can access the option from:
  • The Oasis montaj Geosurface > Utilities > Convert Elevation Grid to Surface menu
  • The Oasis montaj 3D ViewGeosurface > Utilities > Convert Elevation Grid to Surface menu
  • The 3D Viewer Geosurface > Utilities > Convert Elevation Grid to Surface menu
Convert Elevation Grid to Surface dialog options
Elevation grid
Specify the name of the input relief grid. The grid cannot have a section orientation.
Script Parameters: IMPORTGRID2SURF.INPUT_GRID
Output geosurface
Specify the name of a new or existing geosurface file.
Script Parameters: IMPORTGRID2SURF.OUTPUT_SURFACE_FILE
Surface name
Select a name for the new surface. By default, it will be the root name of the input grid.
Script Parameters: IMPORTGRID2SURF.OUTPUT_SURFACE_NAME
Colour
Select a colour for the surface. The default colour is Magenta.
Script Parameters: IMPORTGRID2SURF.SURFACE_COLOR
Requirements
  • The input grid must be an elevation grid; section grids are not allowed.
  • The Z-values in the grid are interpreted as elevations using the same distance units as the coordinate system; i.e., X, Y, and Z are all the same units. Each node in the grid results in a node on the triangulated surface.
