Join, Clip, or Intersect Closed Surfaces
Use the Join, Clip or Intersect Closed Surfaces option (geogxnet.dll(Geosoft.GX.Surface.SurfaceBooleanOperations;Run)*), to combine two closed surfaces.
You can access the option from:
  • The Oasis montaj Geosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
  • The Oasis montaj 3D ViewGeosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
  • The 3D Viewer Geosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
Join, Clip, or Intersect Closed Surfaces dialog options
Primary geosurface
Select the geosurface file containing the primary surface.
Script Parameters: SURFACEBOOLEANOPERATIONS.PRIMARY_GEOSURFACE_FILE
Primary surface
Select the name of the primary surface from the list of surfaces in the primary geosurface file. It must be a closed surface.
Script Parameters: SURFACEBOOLEANOPERATIONS.PRIMARY_SURFACE
Secondary geosurface
Select the geosurface file containing the secondary surface. This may be the same file as the primary geosurface file.
Script Parameters: SURFACEBOOLEANOPERATIONS.SECONDARY_GEOSURFACE_FILE
Secondary surface
Select the name of the secondary surface from the list of surfaces in the secondary geosurface file.
Script Parameters: SURFACEBOOLEANOPERATIONS.SECONDARY_SURFACE
Select action
Select the action to be performed on the two input surfaces:
  • Cut primary with secondary: remove the volume within the primary surface that is also within the secondary surface, producing a closed surface that encloses the volume unique to the primary surface.
  • Cut secondary with primary: remove the volume within the secondary surface that is also within the primary surface, producing a closed surface that encloses the volume unique to the secondary surface.
  • Create union of both: Join the two closed surfaces to produce a single surface that encloses the entire volume enclosed by either of the individual surfaces.
  • Intersection of both: Create a closed surface that encloses only the volume that lies within both input surfaces.
Script Parameters: SURFACEBOOLEANOPERATIONS.BOOLEAN_OPERATION
Output geosurface
Specify the output geosurface file in which the resulting surface will be written. This can be the same file as either input geosurface file, another existing geosurface file, or a new geosurface file.
Script Parameters: SURFACEBOOLEANOPERATIONS.OUTPUT_GEOSURFACE_FILE
Output surface name
Specify the name of the output surface. If a surface with the same name already exists in the output geosurface file, it will be overwritten.
Script Parameters: SURFACEBOOLEANOPERATIONS.OUTPUT_SURFACE
Colour
Specify the colour of the output surface.
Script Parameters: SURFACEBOOLEANOPERATIONS.SURFACE_COLOR
Coordinate Systems
  • A new output geosurface will have the same projected coordinate system & units as the primary input geosurface.
  • If the output geosurface already exists, the resulting surface(s) will be reprojected into the projected coordinate system and units of the output geosurface.
