Dap Base Map
Use the DAPMAP GX to create a default base map for a specified latitude/longitude area. This GX first asks for the bounding latitude, longitude area, then asks for parameters to create and draw a base map:
Data Range to Map dialog options
Minimum Longitude, |
Specify the longitude range for the area of interest in degrees (negative in the Western hemisphere). |
Minimum Latitude, |
Specify the latitude range for the area of interest in degrees (negative in the Southern hemisphere. |
Create a New Map
Map name |
The name of the new map. |
Select a standard template to be used to define the map layout. The map layout includes the media size, map margins and basic map drawing style. The [Templates] button will enable you to modify existing templates and add your own new templates. |
The desired map scale. If left blank, a default scale will be chosen to fit the data range to the specified template. The [Scale] button will cause the default scale to be calculated displayed so that it can be modified to an appropriate scale if desired. |
Title |
A title and sub-titles for your map. These will be drawn at the bottom centre of the map. |
Coordinate system |
A default coordinate system will be created to reasonably display your data. This is the text description of the coordinate system that is created. |
Scale |
Calculate and display a default scale that will fit the defined data range to the specified template. |
A default map projection is created to display the requested area. Latitude, Longitude surrounds are drawn on the map by default.
