Duplicate Map
Use the Map > Duplicate Map menu option (DUPMAP GX) to create a duplicate/copy of the current map.
Duplicate Map dialog options
New map name
New map name.
Script Parameter: DUPMAP.MAP
Contents
New map contents: "Blank", "Copy current contents"
Script Parameter: DUPMAP.CONTENTS
0 - "Blank", 1 - "Copy current contents"
This option enables you to select a map and create a copy with a different name. You may want to use this capability for creating test interpretations or editing maps without altering the original. You can also select whether you want the new map to contain the contents of the current map or not.
