Database Channels to Array
Use the Database Tools > Array Channels > Database Channels to Array menu option (geogxnet.dll(Geosoft.GX.Database.ChannelsToArray;Run)*) to select and display standard database channels as an Array channel.
Database Channels To Array dialog options
New array channel
Specify the name of the New array channel in the text box provided.
Database channels
The channels in your current open database are displayed in the Database channels list.
Array channel elements
The array channel elements for your new array channel are displayed in the Array channel elements list.
[Add]
Select (highlight) the database channels to be added to an array channel. Click the Add -> button to move the selected channels to the Array channel elements list.
[Remove]
Select (highlight) the array channel elements to be removed from an array channel. Click the <- Remove button to move the selected array channel elements to the Database channels list.
