Resistance Capacitance Filter
Use the Resistance Capacitance option to apply a Fast-Fourier Transform Resistance Capacitance filter to a database channel.
  • Geophysics: 1D FFT > 1D Filtering
  • Gravity and Terrain Correction: Moving Platform Gravity  > Apply Single FFT Filter
Resistance Capacitance filter options
Central Wavelength cutoff
(in ground units)
Specify the Central Wavelength cutoff value, in ground units.
(Default is 1)
Script Parameter: FFTRC.WAVEL
Low or High Pass Filter
Select Low or High Pass filter.
(Default is Low)
Script Parameter: FFTRC.PASS
The Resistance Capacitance filter is excellent for smoothing the gravity data.
Parameter:
kc
Central wavenumber of the filter.
