Expand Grid
Use the Grid and Image > Utilities > Expand Grid menu option (geogxnet.dll(Geosoft.GX.GridUtils.GridExpand;Run)*) to expand a grid by adding dummies to the new expanded region beyond the edges of the old grid. This is designed mainly to provide a bordering area to be filled by GRIDFILL in preparation for MAGMAP.
Expand Grid dialog options
Input grid file
Input Grid file name.(.grd file)
Script Parameter: GRIDXPND.GRDIN
Expanded output grid
Output Expanded Grid file name.(.grd file)
Script Parameter: GRIDXPND.GRDOUT
Minimum % to expand the grid
Minimum percentage to expand the grid.(Default = 10.0)
Script Parameter: GRIDXPND.MINPER
Shape of the output grid
Shape of the output grid.(Can be 'SQUARE' or 'RECTANGLE'. default is 'SQUARE')
Script Parameter: GRIDXPND.SHAPE
Expand X dimension to
Dimension in X direction which the input grid is expanded to.
Script Parameter: GRIDXPND.XDIM
Expand Y dimension to
Dimension in Y direction which the input grid is expanded to.
Script Parameter: GRIDXPND.YDIM
GRIDXPND.XDIM and GRIDXPND.YDIM will default to input grid dimension values if they are not specified, or if they are set to 0.
The default dimensions are chosen to be compatible with the Wynograd FFT used by MAGMAP.
