Import Single Table
Use the Database > Import > Database Table > Single Table menu option (IMPDB GX) to import external file databases into a Geosoft database (GDB). The GX assumes that the database is a Microsoft Access database (with a .mdb file extension). If it is not, and the system can not identify its type, the system prompts you for it. The supported databases depend on the ODBC drivers that have been installed on the system.
Import Single Table dialog options
File to Import
Choose the file to import or type in an existing file name.
Selection
This can be one of the following options:
  • Selected Table & Fields
  • SQL Selection
By choosing the 'Selected Table & Fields' option, a dialog will open to select a table (if more than one) and fields to import.
By choosing the 'SQL Selection' option, a dialog will open to specify a SQL selection string and an Oasis montaj group name to create.
The following lists the typical ODBC drivers that come installed with a Microsoft Windows system:
  • Microsoft Access Driver (*.mdb)
  • Microsoft Excel Driver (*.xls)
  • Microsoft dBase Driver (*.dbf)
  • Microsoft Paradox Driver (*.db)
  • Microsoft FoxPro VFP Driver (*.dbf)
  • Microsoft Visual FoxPro Driver
  • If the "Specify coordinate system on import" setting is set to "Yes" in the General Settings, and if no coordinate system is defined in the current X and Y channels, the "Georeference Database Channels" dialog is called so that the projection can be set on the X and Y.
  • The system creates an import template "impdb.i4" at import time. This is to enable advanced users to tailor the import channel name or data type (for automated import) using GX Developer functions.
    • SQL (Structured Query Language) is a computer language designed to store, manipulate, and retrieve data from a relational database. SQL commands are used to select data from the tables located in a relational database.
    • For more information on SQL visit http://en.wikipedia.org/wiki/SQL
    • For a SQL tutorial go to: https://www.1keydata.com/sql/sql.html
