Default Attributes
Attributes may be defined as they are needed, or they may be selected from a default set of attributes defined in a file named MAPPLOT.AAT. (the INIT command can be used to select a different default attribute table). When MAPPLOT starts up, the system path is searched for the default AAT file. If this is found, then the attributes it contains are defined for use in the control file being processed. These attributes may be re-defined or overridden by attribute definitions in the control file. The output attribute file will contain all the default attributes from MAPPLOT.AAT, plus any new attributes defined in the control file.
The MAPPLOT.AAT is an ASCII file with the same format as produced by the PLATT program. It may be modified using a text file editor. The following are the default attributes supplied with MAPPLOT.
1 255 0 0 0 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
2 255 0 0 0 300 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
3 255 0 0 0 450 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
4 255 0 0 0 600 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
5 0 0 255 255 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
6 0 255 0 255 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
7 0 255 255 0 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
8 0 255 0 0 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
9 0 0 255 0 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
10 0 0 0 255 150 1 0.0 0 0 0 0 3.0 3.0 3.0 0.0 DEFAULT
The columns are defined as follows:
Label_field |
Attribute label consisting of up to 15 characters (no spaces). The label is used to specify the attribute in the control file. |
lb lc lm ly |
Black, cyan, magenta and yellow colour intensities (integer values between 0 and 255) that define the colour. |
thk |
Line thickness in microns |
sty |
Line style |
ptc |
Line pitch in millimetres |
fb fc fm fy |
Black, cyan, magenta and yellow colour intensities (between 0 and 255) that define the fill colour for polygonal features and filled symbols |
ht wd sp sl |
Text height, width and spacing in millimetres, and slant in degrees from vertical. |
font |
Text font |
