Save Database As
Use the Database > Save As menu option (SAVEGDB GX) to save the current database to a new file.
Save Database As dialog options
New database file
The name of the new database file.
Script Parameter: SAVEGDB.NAME
Compression type
The type of compression to use with the new database:
  1. None - No compression of any kind
  2. Speed - Compress with database performance in mind. This is usually faster than no compression.
  3. Size - Compress with database size in mind. This will achieve the smallest database size.
For a description of each compression type, click here.
Script Parameter: SAVEGDB.COMPRESSION
The current database will be saved to a new file; all changes will be committed to the new file. The original database will be closed after discarding any changes.
