Save Map As
Use the Map > Save As menu option (SAVEMAP GX) to save the current map to a new map. The original map file will be closed.
Save Map As dialog options
        Map name  |
        Specify the name of the new map. Script Parameter: SAVEMAP.MAP  |
Any changes to the current (original) map will appear in the new map; however, the changes will be discarded from the original map which will be closed.
If a grid is the active window, the Open in New Map button on the Grid Viewer toolbar allows you to save the current grid to a new map. The new map will be created in the current project directory and opened in Oasis montaj. See Save and Open Grid as Map for more details.
