Add/Replace Group Mask
Use the Map Tools > Masking > Add/Replace Group Mask menu option (VIEWEXTCLIP GX) to add or replace a group mask to a view.
Add/Replace Group Mask (1 of 2)
Clip polygon file (.ply)
Browse for a file containing the polygon you wish to use as a group mask.
Script Parameter: VIEWEXTMASK.FILE
Map view
Select the view to remove the group mask from.
Script Parameter: VIEWEXTMASK.VIEW
Add/Replace Group Mask (2 of 2)
Group mask name
Choose a group mask name or pick an existing one to replace in the view.
Script Parameter: VIEWEXTMASK.NAME
Set mask for all groups in view?
Assign the group mask to all groups in the view. Default: No
Script Parameter: VIEWEXTMASK.FORCE
Group masks provide the ability to have more control over masking of map elements than by just defining a single clipping area per view (see Apply View Mask (VIEWCLIP GX) documentation). After adding group masks to a view, groups within the view can be masked to the specific named area. To do this open the Group/View manager and select a group mask region from the drop down box. Select None to remove this masking attribute from a group.
Note that the view mask region as described in Apply View Mask can be active in addition to a group mask. Also see the Apply View Mask documentation for a further discussion on PLY files.
