Calculate Vp
Use the Calculate Vp option to calculate the potential voltage at the receivers from the database electrode configuration and selected apparent resistivity channel values.
Calculate Vp dialog options
Apparent resistivity channel |
Input resistivity channel name. This entry is mandatory. Script Parameter: IP_CALCUALTE_VP.APPRES_CHANNEL |
Current type |
The current can be provided either as a channel or a constant. Script Parameter: IP_CALCUALTE_VP.CURRENT_TYPE[1 – Channel specified ( default), 0 – value] |
Current channel or Current value |
If you selected current channel above you will be prompted to provide the channel name. Otherwise you will be prompted to supply a single current value. If you have no knowledge of the current value or if you have an indication that it few different current intensities were used, you could enter a value or 1, in which case the output potential will be the normalized potential value. Script Parameter: IP_CALCUALTE_VP.CURRENT_CHANNEL or IP_CALCUALTE_VP.CURRENT_VALUE |
Output Vp channel |
Channel name for the output potential at the receivers. This entry is mandatory. Script Parameter: IP_CALCUALTE_VP.OUTPUT_CHANNEL |
Transmitter 1 & 2 |
Transmitter 1 is required for all IP configurations. Define the channel names for the coordinates of transmitter 1. If the configuration supports a second transmitter, proceed to enter the coordinates of transmitter 2. Script Parameter: IP_ SORTBYRXTXORDER.T1X, T1Y, T1Z IP_SORTBYRXTXORDER.T2X, T2Y, T2Z |
Receiver 1 & 2 |
Receiver 1 is required for all IP configurations. Define the channel names for the coordinates of receiver 1. If the configuration supports a second receiver, proceed to enter the coordinates of receiver 2. Script Parameter: IP_ SORTBYRXTXORDER.R1X, R1Y, R1Z IP_ SORTBYRXTXORDER.R2X, R2Y, R2Z |
The equations for calculating the Vp are:
Dipole-Dipole Vp:
Pole-Dipole Vp:
Pole-Pole Vp:
Where ρ is the resistivity.
