Font Attributes
Use the Font Attributes dialog to modify the attributes of the selected font.
Font Attributes Dialog
Font |
Use the Font drop-down list to select the font (Geosoft or True Type) to choose from. |
Character Set |
Use the Character Set drop-down list to select the character set to choose from. |
Reference |
Use the Reference drop-down list to select the reference location to plot the font character. |
Size |
Specify the Size of the font in either point or millimetres. |
Select the radio button point (pt.) or millimeters (mm) for the selected font. |
Weight |
Use the Weight drop-down list to select the weight of the selected font. |
Colour |
To select the Colour of the pattern, click inside the coloured box below. The Colourtool will be displayed. |
Italic |
Check the Italic box to display the selected font in italics. |
Rotation |
Specify the rotation angle of the font in degrees counter-clockwise from the map coordinate system. Normally, this angle is 0. |
Font display |
The selected fonts are displayed in the window at the bottom of the dialog. |
