Pattern Attributes
Use the Pattern Attributes dialog to modify the attributes of the selected pattern. The dialog opens from the Polygon Attributes dialog.
Pattern Attributes dialog options
Pattern family |
Use the Pattern family drop-down list to select the "family" of patterns (Solid fill, Objects, Hatches, Geology,
MapInfo and |
Pattern |
Select a Pattern from the list of displayed patterns in the box below. |
Colour |
To select the Colour of the pattern, click inside the coloured box below. The Colour tool will be displayed. |
Background |
To select the Background colour of the pattern, click inside the coloured box below. The Colour tool will be displayed. |
Tile size (mm) |
Specify the Tile Size of the pattern in millimetres. |
Tile density |
Specify the tile density of the pattern. |
Line thickness
Specify the line thickness (% of Tile size) of the pattern. |
Example |
An example of the selected pattern including all of the modified parameters (Size, Density, thickness) is displayed in the window of below. |
Refresh |
Click the Refresh button to update the Example box when changes have been made to any of the parameters. |
When selecting patterns from the MapInfo or
