Polygon Attributes
Use the Polygon Attributes dialog to modify the polygon attributes of the selected polygon.
To access the Attributes tool:
Ensure the group to be edited is displayed on the map.
In the Map Manager tree, select the group layer and right-click Edit Vector Group. A shaded frame will appear around the group on the map.
Click inside the frame, and the area to be edited will be highlighted by square symbols. Right-click and select the Attributes option.
To select the entire group, mouse over the selected group and right-click Select All. Right-click again and select Attributes.
Polygon Attributes Dialog
Edge |
Draw edge |
Check the Draw edge box, to enable/disable the Draw edge parameters. Click inside the Colour box to display the Colour tool. |
Styled edge |
Check the Styled edge box, to enable/disable the Styled edge parameter. Click inside the Style box to display the Line Pattern Attributes dialog. |
Thickness (mm) |
Specify the thickness of the polygon in map units (mm). |
Smooth edge |
Check the Smooth edge box to smooth the polygon. |
Fill |
Filled |
Check the Filled box, to enable/disable the Filled parameters. Click inside the Colour box to display the Colour Tool. |
Pattern fill |
Check the Pattern fill box, to enable/disable the Pattern fill parameter. Click inside the Pattern box to display the Pattern Attributes dialog. |
