Apply a Mathematical Expression in the Spreadsheet Window
Using the Oasis montaj advanced status bar feature, you can apply a mathematical expression to the data selected in your spreadsheet window.
Also available is the Channel Math Expression Builder, an easy-to-use standardized tool that enables you to create, save, load and execute mathematical expressions for your channel data.
To Apply a Mathematical Expression:
Select the data cells you want to change. You can select a section of a channel, an entire channel on a single line, or the same channel on all lines of the database.
Click the equal sign key (=). This changes the status bar of the spreadsheet window located along the bottom to "Formula=".
In the Formula= text box field, type an expression where the variables are existing channel names.
Click Enter. The result of the expression is placed in the currently selected cells.
For a complete list of the operators and functions, refer to the Rules for Mathematical Expressions.
Examples:
Subtract channel values:
To define an expression that subtracts a "Level" channel from a "Mag" channel and places the results in the "Mag_level" channel:
type the following in the Formula= field:
Calculate distances between points:
To calculate the distance between each point and the origin of the local coordinate system:
This expression assumes that "x" and "y" are coordinate channel names.
