Project Explorer Database Tools
The Project Explorer provides database tools that enable you to perform the following tasks:
Create, Open, or Remove Database(s) :
  1. Select (highlight) the Databases icon in the Project Explorer, right click and select the desired option from the popup menu.
  1. The New Database option displays the New Database dialog. Specify the information in the fields and click the OK button. A new database will be created and added to your current project.
  2. The Open Databases option displays the Add New Database(s) dialog. Select the database(s) to be added and click the Open button. The database(s) will be added to your current project.
  3. The Remove All Databases option removes all databases from your current "Project" but does not delete the database files from the project directory.
Remove, Open File Location, Rename, Delete, or View Database Properties or Metadata:
  1. Select (highlight) the database name, right click and then select the desired option from the popup menu.
  1. The Find option is available when the source file of the selected database document is missing (the database appears in grey along with a warning icon ). Use this option to open the browse dialog and locate the missing file. See Missing Data Files for more details on the Find functionality.
  2. The Remove from Project option will remove the database from the "Project" but will not delete the database from your directory.
  3. The Open File Location option will open the Windows File Explorer to the location of the database file selected.
  4. The Properties option will display the database Properties dialog. Click the More button to display more database property parameters. Click the OK button to close the dialog.
  5. The Metadata option will display the Metadata Viewer dialog. Click the Edit button on the Metadata Viewer to display the Metadata Editor. Click the OK button to accept your changes and close the dialogs.
  6. The Rename option renames the database in the project as well as on the disk. Any auxiliary files (e.g.,.xml) will be renamed at the same time.
  7. The Delete option deletes the database from the project as well as from the disk.
