Shift or Scale a Surface
Use the Shift or Scale a Surface option (geogxnet.dll(Geosoft.GX.Mesh.Transformation.TransformMesh;Run)*) to transform an existing surface to create a new version with a different size or position. The entire surface is shifted or scaled by the same amount, resulting in no internal deformation. The new surface may be written to a new, existing, or to the same (input) geosurface file.
You can access the option from the following locations:
The 3D View > Geosurface > Utilities menu
Shift or Scale a Surface dialog options
Input geosurface |
Select the geosurface file containing the surface to be transformed. It is recommended that the geosurface file has a valid coordinate system defined. Script Parameter: TRANSFORMSURFACE.INPUTSURFACEFILE |
Surface to modify |
Select the name of the surface to be transformed from the list of surfaces in the geosurface file. Script Parameter: TRANSFORMSURFACE.INPUTMESHNAME |
Output gesourface |
Specify the output geosurface file to which the transformed surface will be written. This can be the same file as the input geosurface file, another existing geosurface file, or a new geosurface file. Script Parameter:TRANSFORMSURFACE.OUTPUTSURFACEFILE |
Output surface name |
Specify the name of the output transformed surface to be created. If a surface with the same name already exists in the output geosurface file, you will be prompted to specify a name that is unique within the geosurface file. Script Parameter: TRANSFORMSURFACE.OUTPUTMESHNAME |
Operation |
Choose between the shift and scale operation. Script Parameter: TRANSFORMSURFACE.TRANSFORMATIONTYPE [0: scale (default), 1: shift] |
ShiftAt least one shift value must be nonzero.
X shift |
Specify the amount to shift every surface node along the X-axis. Script Parameter: TRANSFORMSURFACE.DELTAX |
Y shift |
Specify the amount to shift every surface node along the Y-axis. Script Parameter: TRANSFORMSURFACE.DELTAY |
Z shift |
Specify the amount to shift every surface node along the Z-axis. Script Parameter: TRANSFORMSURFACE.DELTAZ |
ScaleThe scale values must be positive and at least one scale factor must not be ==1.
X scale factor |
Specify the amount to scale (multiply) the X-coordinate of every node in the surface. This must be a positive value. Script Parameter: TRANSFORMSURFACE.DELTAX |
Y scale factor |
Specify the amount to scale (multiply) the Y-coordinate of every node in the surface. This must be a positive value. Script Parameter: TRANSFORMSURFACE.DELTAY |
Z scale factor |
Specify the amount to scale (multiply) the Z-coordinate of every node in the surface. This must be a positive value. Script Parameter: TRANSFORMSURFACE.DELTAZ |
The scaling operation is simple multiplication; coordinates are scaled relative to the origin of the coordinate system, rather than some local origin.
